I have 1995 Jeep Wrangler. I had it put in the shop last year for electrical problem, It would die and not start for a while then all of a sudden it starts it would also have headlights going on and off. winshield wipers going off w/ every bump. They fixed and it ( A short in the wiring behind the dash and it ran a whole year w/ no problems. All of a sudden the same thing starts up this spring, the wierd thing is if you let it sit a half hour or so it will start, sometimes longer or shorter, but it walways dies again. I put it back in the shop three times w/ no success. Could it possibly be something else that we are simply missing. I have replaced the distribtor cap the pin, fuel pump and everything involved with that except the actual tank. Do you have any suggetions to try before getting rid of it. Could it possibly be not the wiring again but the coil and if so how would i check it?
May 30, 2008 at 4:14 PM
