Hey kathy, I am pretty sure the instructions should state to mark the vacume hoses before you took old carb off(so you knew where to install them on new carb). Because the eng. Won't start with too many open vacume sources. How the plugs look(fouled?) Yoy may have a weak ign. Sys.(Coil/wires/cap/rotor?) Make sure pick up in dist is clean(no rust) you have to ck. The timing(suonds like it might be an issue also) but ya gotta have it running to ck tje advance, oh yeah ck. The vacume advance on dist. Also. Hopefully the vacume lines will kind of lay where they need to be otherwise, get a book on that veh, or try to find a vacume diag. Under hood some where. Good luck let me know what you find.
SPONSORED LINKS
Tuesday, March 6th, 2007 AT 5:23 PM
