i think its the carb not sure though
1987 JEEP WRANGLER
136,000 MILES
WOOTYWOOT
ok so i can get my jeep running at times but the only way to keep it running is to tap on the gas and its puffin white smoke and dosent idle right and just sounds like garbage also when it stalls or i shut it off the carb dumps gas ...im thinking i have to rebuild the carb but im no expert here im compleatly lost when im under the hood please help your input would be greatly apprecieated thank you for your time
May 7, 2013 at 8:55 AM
dumping fuel is an indication of flooding. yes, it needs to be re built
May 7, 2013 at 9:28 AM
WOOTYWOOT
Thank you can u think of any thing else it could be a friend suggested my timing was off but I'm no mechanic here so idk and thank you again for your answer
May 7, 2013 at 9:31 AM
start with the carb
roy
May 7, 2013 at 9:47 AM
WOOTYWOOT
OK thank you
May 7, 2013 at 9:56 AM
