Here's one more tidbit I want to add. I don't think this applies to your Jeep, so it's mainly for the benefit of owners of other models who may be researching this topic. I've witnessed this three times, and been involved with two of them. The first was on a '92 Dynasty at the dealership. This is where I first learned of this. The second was that friend of mine has a body shop where he specializes in rebuilding smashed one and two-year-old Chrysler products, mainly trucks, and the third was on a '95 Intrepid used by one of Chrysler's trainers, then donated to my community college.
Let me start with my friend who rebuilt an early 2000s Neon. One of the last damaged items to be replaced was the Engine Computer. To verify everything else was okay, he borrowed the computer from another friend's car. The rebuilt car fired right up and ran fine, so all that was needed was to order his own computer. As soon as they put that borrowed computer back into his friend's car, it was a crank / no-start. They trailered it to a dealership, and the fix was to replace the Engine Computer and the Body Computer at the same time.
In the cases of the Dynasty and the Intrepid, both also needed replacement Engine and Body Computers at the same time. The owner of the Dynasty replaced the Engine Computer himself earlier, which turned out to not be the cause of the original problem. One of my students borrowed the Engine Computer out of our Intrepid to see if it would solve a problem in his car. It did not, but now our Intrepid was also a crank / no-start once the original computer was reinstalled.
What happens is the car could have factory anti-theft from the factory, or it could not have that option. If it does, the software in the Engine Computer and in the Body Computer has the programming for that. Anti-theft programming can not be undone except by the people who rebuild those computers. A better way to say it is that programming is in both computers, but it was never activated if the car didn't come with the optional anti-theft system
When you have a car without the anti-theft system, you must only install replacement Engine or Body Computers that also have never had it activated. As long as that remains true, you can swap computers back and forth all day and never cause a problem. Also, when you buy a replacement computer from the dealer's parts department, they always come with anti-theft not activated.
This is where the potential problem comes in. If your car has the factory-installed anti-theft system, lets say you replace the Engine Computer with a new one from the dealer, the Body Computer will teach that anti-theft programming to the new computer the instant you turn on the ignition switch. You don't have to do anything special, and there's no indication that change has taken place. Both computers will function normally. The same is true if you replace the Body Computer. It learns the anti-theft programming from the Engine Computer. In either case, once that programming has been activated, it can't be deactivated. It's burned into the software permanently.
It's when you take a used computer with anti-theft system activated, and put it in a car without the factory-installed system, it teaches it to the other computer the instant you turn on the ignition switch. Now both computers need to see the "disarm" signal from the door lock cylinder or remote key fob, before they will work, but those don't exist, so that signal is never coming.
At this point competent do-it-yourselfers assume the replacement Engine Computer is defective, so they try another one. That one also learns the anti-theft programming if it wasn't already activated. This will go on and on until it is realized both computers have to have deactivated software, and be installed at the same time. It took me most of the school year to convince my tool room attendant of this. He kept on replacing computers one at a time, and never got that engine running until I found a pair of computers without the anti-theft activated, and had a student install both at the same time.
One important variation of this is on '97 Caravans, and probably other model years. In these vans, one computer doesn't teach the anti-theft programming to the other one simply when turning on the ignition switch. Instead, that occurs when the lift gate is unlocked with the key. There's a switch in the latch assembly that triggers that learning. That switch doesn't exist on vans without the anti-theft system, so a replacement computer will never teach it to the other computer. The new computer with activated anti-theft will not work, as before, but it won't harm the other computer. In this model, it is safe to just try multiple computers until you stumble across one with the anti-theft not activated. That one will work like normal.
SPONSORED LINKS
helpful?Yes
Sunday, January 10th, 2021 AT 5:55 PM
