1988 Jeep Wagoneer Stalls When Accelerating
JEEP
G3A3R5Y9
1988 Jeep Wagoner limited, 4.0 179,000 miles; i replaced the ignition coil, but it still stalls when we back-up or pull out. It doesn't do it all the time,it seems to do it when you ease on the gas
May 4, 2006 at 12:01 PM
PEPPERMRJ
  • 1,158 POSTS
Some things to do.
Check for vacuum leaks. Leaky hoses and connections can cause an erratic idle and stalling.
Change your fuel filter. Run some fuel injector cleaner thru a tank or two. I like chevron with techron.
Clean the throttle body. Make sure it is tight.
Clean the EGR valve. Make sure it is functioning properly.
Change the PCV valve. I prefer OEM parts for this. Make sure there are no leaks.
I assume since you changed the coil the rest of the ignition system is also new. Properly gapped plugs, wires, cap and rotor(if used) can all contribute to stalling.
Good luck and let us know. :)
May 6, 2006 at 12:07 PM
Suggested Repair
Check for vacuum leaks, replace the fuel filter, and run fuel-injector cleaner. Clean the throttle body and EGR valve, replace the PCV valve with an OEM part, and verify plugs, wires, cap, and rotor are in good condition and properly gapped.
Conversation Summary
A 1988 Jeep Wagoneer Limited with a 4.0 engine and 179,000 miles stalls intermittently when backing up, pulling out, or easing onto the gas, even after the ignition coil was replaced. The expert suggested checking vacuum leaks, the fuel filter and injectors, throttle body, EGR valve, PCV valve, and the rest of the ignition system.
