no start
JEEP
CTULUMBAS
1996 jeep sport 4 wd. 4.0 in line 6 cylinder engine.Will not start. changed distributor cap and rotor, checked coil. changed fuel pump (in tank), fuel filter, cleaned fuel lines. I dont know what else to try.
Dec 7, 2006 at 12:21 AM
CARUNDELL
  • 602 POSTS
[quote:9de8a898cd="ctulumbas"]1996 jeep sport 4 wd. 4.0 in line 6 cylinder engine.Will not start. changed distributor cap and rotor, checked coil. changed fuel pump (in tank), fuel filter, cleaned fuel lines. I dont know what else to try.[/quote:9de8a898cd]
Hey ct,
Some basic info first
1. Do you have adequate spark when cranking?
2. Do you have adequate fuel pressure when cranking?
Get us this info and we can help more!
Regards,
Chris
Dec 7, 2006 at 1:25 AM
MWHITNEY
  • 63 POSTS
dude like the guy said check for a really good spark. I seen jeeps with a no start problem no power going to fuel pump and so on. If you check for a really good spark and there is none. look at the chank sensor.
Dec 11, 2006 at 2:26 AM
