Jeep Wrangler Brake Line Air
JEEP
MCCOYSURFER
I was changing the rotors and brake pads on my Jeep Wrangular and I made the mistake of taking the brake fluid line off the, calibur, I believe it is. I tried the process of bleeding it but there is still air coming from the nut where the brake fluid line attaches to the calibur. I tried to make it tighter but still no good. what am I doing wrong?
Apr 22, 2007 at 7:18 PM
  • 75,988 POSTS
[quote:a86a2c3a1a="mccoysurfer"]I was changing the rotors and brake pads on my Jeep Wrangular and I made the mistake of taking the brake fluid line off the, calibur, I believe it is. I tried the process of bleeding it but there is still air coming from the nut where the brake fluid line attaches to the calibur. I tried to make it tighter but still no good. what am I doing wrong?[/quote:a86a2c3a1a]
My friend you're doing it wrong.-there's a nipple looking like a grease fitting with a rubber dust cover that's where you bleed from.
You probably crossthread it-now you need a new brake line to the caliper. Did you find the grease fitting looking thingy.
Apr 22, 2007 at 10:14 PM
Suggested Repair
Bleed the brakes at the caliper bleeder nipple (the grease-fitting-like screw with a rubber dust cover), not at the brake line nut. If the line fitting was cross-threaded, replace the brake line to the caliper.
Conversation Summary
The owner disconnected the brake line at the caliper while changing rotors and pads on a Jeep Wrangler, then still saw air at that fitting after trying to bleed and tighten it. The expert said bleeding must be done at the bleeder nipple under the rubber dust cover, and that a cross-threaded line fitting likely means the brake line to the caliper needs replacement.
