1995 Jeep Grand Cherokee Door Radio Blank
1995 JEEP
I have a 95 jeep grand chreekee lardo and in the last few days i noticed when i open any door my radio and vichecil display screen wound go blank and get no response till i shut the door also when the doors open there a clicking sound coming from under the dash on the passnger side i checked all the fuses there all working when i pull the #5 fuse for interior lights the clicking stops what is wrong is there a relay under the dash i missing ?
Mar 4, 2007 at 4:23 AM
YUP THERE IS A RELAY THERE RIGHT SIDE UNDER DASH , YOU CAN PUT YOUR HAND ON IT AND FIND THE CULPRIT , AND SWAP IT OUT WITH ONE OF THE SAME PART NUMBER FOR CHECKING PURPOSES AND IF THINGS WORK OK ON THE FIRST PROBLEM, GET ANOTHER RELAY JUST JOT DOWN THE PART ## CHECK YOUR MANUAL FOR RELAY LOCATION AND WHAT IT FEEDS
Mar 4, 2007 at 4:39 AM
Suggested Repair
Locate the relay on the right side under the dash and identify the clicking unit by feel. Swap it with a relay of the same part number to test. If the radio and display stay on with a door open, replace that relay. Check the manual for the relay location and the circuit it feeds.
Conversation Summary
On a 1995 Jeep Grand Cherokee Laredo, opening any door blanks the radio and vehicle display until the door is closed, and a clicking sound comes from under the passenger-side dash. Fuses were checked and pulling interior-light fuse #5 stops the clicking. The expert said a relay on the right side under the dash is the likely cause and recommended finding it by feel, swapping it with a same part-number relay to test, and replacing it if that fixes the problem.
