4-way flashers and turn signals
JEEP
RMJ
Just recently my turn signals and 4-way flashers just stopped working.Then all of a suden they started working again.A few days went by and again they stopped.Another few days went by,and they started working.I went to see if this was a fuse problem.Come to find out it wasn't.The fuses were all ok,but the 4-ways and turn signals still acted crazy!What could this possibly be?PLEASE HELP!!!
Jun 26, 2007 at 3:24 PM
MIKEMRRYMN
  • 7 POSTS
sounds like you may have a short somewhere or a bad ground on the lighting system, could be a loose plug or connector, check the fuse box to make sure the flasher modules are both secure and working properly, if there are two of them, check all plugs and connections near the fuse box to make sure they are all secure, could be just loose plug going in and out of connector when you hit a bump in the road or something without veh type its hard to say where the plugs are located
Jun 26, 2007 at 3:45 PM
