1999 Other Jeep Models My radiater is cracked
1999 JEEP
125,000 MILES • 6 CYL • AWD • AUTOMATIC
CRUTLEY
I am sure of this as my mechanic checked it out. We are going to trade this jeep into the dealership for a new car (we've had it with this jeep!). Is there a "quick fix" type of sealant that would work so we can actually drive the car about 20 minutes to the dealership (rather than pay the $500 repair for a new radiator- even our mechanic thinks we shouldn't do that). The car is valued at only $2000 or so....so putting $500 in would not be good.
Our mechanic said we would probably have to stop about 1/2 way to put water in it (when the engine cooled back off). Just wanted to check and see if there were any other ideas? I had heard from someone there is a "sealant" you can buy for the cracked radiator for a quick and temporay fix.
Thanks!
Nov 8, 2008 at 10:56 AM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
there is a radiator sealant you can put in the radiator but i never suggest using it but if your trading her in then why not. keep a couple gallons of water with you and you should be ok unless its pouring out.
Nov 8, 2008 at 2:09 PM
CRUTLEY
thanks for replying so fast! do you know where i can buy it?
Nov 8, 2008 at 6:48 PM
MASTERTECHTIM
  • 4,750 POSTS
any parts store, its called "bars" stop leak for radiators.
Nov 9, 2008 at 5:31 AM
