2003 Jeep Liberty JERKING, WONT GO OVER 45MP SOMETIMES
CHAMSHAWN
  • 2003 JEEP LIBERTY
Engine Mechanical problem
2003 Jeep Liberty Automatic 87000 miles
i have taken my liberty to the mechanics two or three times for this problem. First the fuel pump was replaced. Then the spark plugs and sensors were replaced. The car is still doing the same jerking motion every few days and at times stops running all together. The mechanic cannot find anything else wrong with it. Any suggestions? -Thanks
Saturday, February 20th, 2010 AT 11:41 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Saturday, February 20th, 2010 AT 5:55 PM
