Jeep Grand Cherokee P0420
ROBIN2
help....had the catalytic converter replaced last dec. under recall. had the muffler replaced this summer. check engine light came on last week. went back to the dealer and they said it was the downstream o2 sensor. took it home, bought one and replaced it. 2 days later same thing. the dealer says i got a bad one and that it cant be the converter. the engine seems to be awfully hot after short drives. How can i tell if the converter is bad without going back to them? The jeep had 187,000 when they recalled the converter and I never had any trouble with it. Now, I have 205,000 and nothing but issues. Its a 4x4 and most of it has been replaced. just did the ignition coil and the ecm was replaced by the dealer in june of '05. i also noticed last nite after it came on (when I parked it and shut it off) that there was a lot of "crackling" noises coming from underneath the jeep towards the center. Any ideas?
Sep 21, 2007 at 6:27 AM
SERVICE WRITER
  • 9,123 POSTS
The cracling is probably the exhaust system cooling down rapidly...from a screaming hot cat. IF there is no air leak in front of the converter, it probably is a bad cat.
You can try to have it diagnosed somewhere else..maybe a different dealer?
Sep 21, 2007 at 10:34 AM
Suggested Repair
Check for an exhaust air leak ahead of the catalytic converter. If none is found, the converter is likely overheating and failing; have it diagnosed at another shop or dealer rather than replacing the downstream O2 sensor again.
Conversation Summary
A Jeep Grand Cherokee Laredo with about 205,000 miles set a P0420 code after a recall catalytic converter and a later muffler replacement. The dealer blamed the downstream O2 sensor; the owner replaced it, but the code returned and the engine ran very hot after short trips, with crackling under the center of the vehicle. The expert said the crackling is likely a very hot converter cooling and that, absent an air leak ahead of the converter, the converter is probably bad, recommending diagnosis at another shop or dealer.
