2004 Jeep Laredo surging
92,000 MILES • V8 • AWD • AUTOMATIC
CARMENGARY
my jeep surges from 1600 to 2000 rpm alot espedially when cruise is set.could this b a bad tps
Dec 24, 2009 at 1:46 PM
BEEF99
  • 152 POSTS
Yes, a TPS could be your answer. I am unfamiliar with the newer engines but I know that TPS has caused vehicles to surge because of the torque converter engaging and disengaging. Also, sometimes a sensor will not set your check engine light off because the sensors need to break a certain barrier before that happens but they could still be bad. If you have a check engine light on, some of your local auto parts stores will check your codes for free just call to confirm that they have this capability first.
Dec 25, 2009 at 12:36 AM
