2001 Jeep Laredo valve body transmission
2001 JEEP GRAND CHEROKEE LAREDO
ANABEL
2001 Jeep Laredo 6 cyl Four Wheel Drive Automatic
where is located the valve body
Oct 5, 2010 at 4:14 AM
CARADIODOC
  • 34,381 POSTS
Inside the transmission. It can be removed after removing the pan, draining the fluid, and disconnecting the linkages. Removing and diagnosing a problem with it is really not a do-it-yourself operation. There are way too many things that can go wrong including replacing steel balls in the incorrect locations, and any tiny speck of dirt can cause improper operation.
caradiodoc
Oct 5, 2010 at 4:26 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to remove pan and filter to gain access valve body inside trans but can be serviced without removal
Hope this helps
Thanks for donate
Oct 5, 2010 at 4:27 AM
