I have a 1999 Grand Cherokee Laredo 4x4 with the 4.0L Engine and automatic transmission. There are 104k miles on it. I am currently in the process of changing the transmission fluid. The pan was dropped, and about half of the total fluid came out. The rest is still in the torque converter. The pan has been put back on and the filter was replaced. When i purchased the new fluid, I got Valvoline ATF +4 fully synthetic. It said that it replaced the old ATF +3. My question is that since the person I bought this Jeep off of had the transmission fluid changed about 50k miles ago, I'm pretty sure there was ATF +3 in it, which is non-synthetic. Even tho the ATF +4 I bought says it is compatible with the ATF +3, I have been told by a couple people not to mix the newer synthetic with the old non synthetic. Since there is still some fluid (about half) left in the torque converter, should I have the transmission flushed out to get rid of the non-sythetic, or can the synthetic be mixed in with no problems. I am going to be away from home where I will not be able to be making repairs for the next couple years, so I really cannot afford to be having any serious problems with the transmission. Please help me out
Jul 10, 2007 at 3:02 PM
