1997 Jeep Laredo Won't start when warm but will start when
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
MALIA1172
The car will start up fine when cool but if driven for 15+ minutes and you turn it off it won't start.
I turn the key the gages, radio and air all work fine but it won't make a clicking sound or make the engine turn. I've tried putting it in neutral to start and it won't. If I let the car cool off for an hour or more I can start it just fine. WTF? Has anyone else had this issue? If so, how did you fix it?
I have a new Interstate battery so it's not that. I've read something about a crank sensor issue and/or a starter solenoid issue possibly creating these symptoms.
Help! I wanna keep loving my pain in the ass car.
Aug 16, 2010 at 3:25 PM
  • 75,988 POSTS
Battery and connections are squared away-could be the following Could be the starter, starter relay/park and neutral switch and ignition switch.
Aug 16, 2010 at 10:10 PM
MALIA1172
Just had the starter replaced. It will start up but then when I stop anywhere after driving it a while it will make clicking noise and not turn over. I pull key out then re insert and will start up fine.
Should I replace neutral switch and ignition switch now?
Aug 24, 2010 at 6:03 AM
