1996 Jeep Laredo loose belt
YARROW
  • 1996 JEEP GRAND CHEROKEE LAREDO
Noises problem
1996 Jeep Laredo 6 cyl Four Wheel Drive
My 96 jeep grand cherokee loredo 4.0L has a loose belt. How do I tighten it?
Friday, January 30th, 2009 AT 12:32 AM
  • 109,885 POSTS
From the front of the jeep look aprox center of fron of engine slightly to the right. There is an adjuster there. You need to first loosten the bolt on the center of the adjuster pulley. Next there is a bolt on the side of the adjuster (15mm I think) that adjust the tensionier in and out. If you tighten the bolt, it will tighten the belt.
Let me know if you have questions.
Friday, February 27th, 2009 AT 12:51 PM
