1993 Jeep Laredo no spark in cold weather
161,000 MILES • 6 CYL • 4WD • AUTOMATIC
NEEDINFO
there is no spark from the distributer in cold weather. warmer weather, it takes a few crank overs to start. after its warm, it will start right away. tested all relays, and engine computer, replaced plugs, wires, and distributer. also my machanic,( in october) replaced my control panel for the heater, this is just about the time this problem started, could the intrusion in the dashboard have started this problem? just thought you should know this info as well. thanks
Jan 7, 2008 at 9:18 AM
2CARPRO JACK
  • 11,533 POSTS
Get a test light and be sure there is power to the coil.One side of the coil should flash when it is being cranked, if not the ECM isnt receiving a crank signal.If it does and there is no spark, the coil is bad
Feb 6, 2008 at 11:33 PM
