1997 Jeep Laredo Engine turns no spark
1997 JEEP GRAND CHEROKEE LAREDO
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
POCKETRODS
  • 11 POSTS
My engine turns over but there is no spark. I can hear the fuel pump activate when key is turned on. My gauges do not move when key is turned on. Cannot retrieve error codes. Have replaced the crankshaft position sensor/no change. where should I turn next
Jul 2, 2009 at 1:59 PM
BMRFIXIT
  • 19,053 POSTS
Check and suspect coil also check ASD relay
with key on do you have check engine light on
crank engine does the light go out
good luck
Jul 2, 2009 at 2:06 PM
POCKETRODS
  • 11 POSTS
---no check engine light when key is on or when cranking thinking maybe camshaft sensor? could it be?
Jul 3, 2009 at 3:36 AM
BMRFIXIT
  • 19,053 POSTS
Its not a cam sensor
if you have NO check engine light on when 1st key on than suspect bad fuse and or wiring to the PCM
let me know
Jul 3, 2009 at 1:56 PM
POCKETRODS
  • 11 POSTS
could this be a bad pcm.? I've checked every fuse and can see any issue with the wires. Is ther a way to check the PCM?
Jul 13, 2009 at 1:07 PM
