1993 Jeep Laredo Hello
1993 JEEP GRAND CHEROKEE LAREDO
211,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICHAELWARKOCZ
4 weeks ago what i believe to bo the original ignition coil had went bad with in those 4 weeks I have replaced the ignition coil 4 times. I have cleaned the plate that it bolts to for a good ground and also since the orignal went bad it takes a little longer to start. thank you for your time. p.s. will a stero system make it go bad?
Mar 16, 2010 at 1:22 PM
BEEF99
  • 152 POSTS
Yes, if a stereo is not properly hooked up, it could cause some issues. Things to check are proper grounding of everything, bare wires rubbing from the battery, any other wires rubbing. What is happening is you are having a short somewhere that is causing you coil to burn out. You will have to trace all wires leading to that feed the coil to see if there is any obvious sign of trouble. If a stereo was put in around the time if the issue or a little while before hand, this may be an indication of your source.
Mar 16, 2010 at 2:41 PM
