2000 Jeep Laredo Engine Cranks Excessively
2000 JEEP GRAND CHEROKEE LAREDO
96,000 MILES • 6 CYL • 4WD • AUTOMATIC
REALTREE
When starting my vehicle cold , it turns over excessively before starting.Start it,shut it off,it starts right up. Let it set for a few minutes or overnight it starts hard. I just had the fuel pump replaced.This did not help. Machanic told me that the pump was bleeding down. Now with new pump ,he sais it is still bleeding down. The thing runs fine, but seems to idle a little rough at times. Machanic recommends changing entire fuel pump module. Is this necessary,or could something else be wrong?
May 14, 2008 at 7:40 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
you need to check the fuel pressure regulator to see if it is bleeding through that.
May 14, 2008 at 7:44 PM
  • 31,937 POSTS
Hi there,
Do this simple test first, when starting, just turn on ignition and wait 2-3 sec then try and start, if it goes then you may have a faulty pressure regulator valve, this can also be checked by having fuel rail pressure test done and see if there is any excessive pressure loss with the engine off.
Mark (mhpautos)
