1993 Jeep Laredo wont go over 20 mph
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
WESTS1994
will not shift to second gear . rpms goes up to high and wont shift
Jul 16, 2010 at 2:48 PM
  • 75,988 POSTS
If the transmission is not slipping-see below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 16, 2010 at 3:20 PM
WESTS1994
u think it maybe speed sensor
Jul 16, 2010 at 3:44 PM
  • 75,988 POSTS
Check and test both the throttle position sensor and vehicle speed sensor
Jul 17, 2010 at 6:45 AM
