Battery appears to be charging and is running a high voltage during operation - about 15 volts. With key in on position voltage reads above 12 but engine will not start. Buzz noise only thing heard with turn of the key to begin start. Jump starting of vehicle works fine and engine will run without fail once started. Again...voltage shows about 15 during operation of vehicle. Placed pretty new battery on trickle charger and amperage never goes above a 2. Is the starter, the alternator or the battery my most likely problem?
Jun 8, 2009 at 1:56 AM
