1977 Jeep CJ7 turn signals don't work
1977 JEEP CJ7
130,000 MILES • V8 • AWD • AUTOMATIC
MALTBIE1
  • 6 POSTS
the turn signals on my jeep don't work at all ive got tail lights and parking lights but no flashy flashy
Mar 15, 2008 at 7:27 AM
MERLIN2021
  • 17,250 POSTS
On the fuse block, locate the steel round piece, it's called the flasher...replace it.
Mar 15, 2008 at 7:31 AM
MALTBIE1
  • 6 POSTS
yeah i checked the relay and she is good. i only get 3 ohms out of her. should i replace it anyway?
Mar 15, 2008 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
Does it click when signals are used? If not try replacing it...
Mar 15, 2008 at 8:37 AM
MALTBIE1
  • 6 POSTS
i tried replacing it, but nothing not even a click. the switch in the colum is in bad shape it only will click once to the left position. i went to look at it but somebody broke a bolt off where you should put a puller. could be the switch
Mar 15, 2008 at 10:41 AM
MERLIN2021
  • 17,250 POSTS
If it's a simple switch and not a multifunction, it should be fairly simple to cut the wires and put in a toggle type...
Mar 16, 2008 at 12:18 AM
77CJ7
  • 8 POSTS
Check the grounds on your front turn signals. Mine was doing the same thing (also the dash blinker lights would stay on constantly when the turn signal would turned on) and it turned out that the grounds were no good. May have to install a ground wire instead of relying on the housing/grill connection.
Mar 16, 2008 at 8:05 AM
MALTBIE1
  • 6 POSTS
ok so herers what i got so far. i replaced the flasher, got the steering wheel off, replaced both park lamps just becuase one was beyond repair. now ive got hazards, but when i turn on the left signal both rear flash and only the L front. when i turn on the right i only get the R front. i haven't replaced the turn signal switch yet i'm picking that up today hopefully. i'm only replacing it becuse the plastic is old and brittle and in many pieces.
Mar 19, 2008 at 2:53 AM
MERLIN2021
  • 17,250 POSTS
Well if the plastic is brittle and busted up, it can be allowing continuity were none should exist...
Mar 19, 2008 at 11:50 PM
MALTBIE1
  • 6 POSTS
ok i think i got it. the switch did not fix anything except it neede to be replaced. the previous owner has both tail turn signals running off the same wire so i just need to clean up the mess. thanks for all the help. it makes hard as hell to figure out whats wrong when someone else mickey mouses crap together.
Mar 20, 2008 at 2:45 AM
