1985 Jeep CJ7 turn signal not working
139,645 MILES • 6 CYL • 4WD • MANUAL
JHOGAN37
i have hazzards and brake lights, and no turn signals. i i can click on it, and it turns back to normal position on the steering column, i changed the 12 volt two prong retangular fuse and still nothing. the dash light is on for the right side but not outside, no clicking noise just contant on in the center position of the turn signal and goes off on dash when you turn signal like youre going right.. what do i do..
Apr 8, 2010 at 4:24 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile and CJ 5/7 recent answers. To qualify me in your eyes! If your hazards work, at all locations, nothing is wrong with the wiring or bulbs or GROUNDS...and the flasher clicks while they work. Sounds like you are going to take an internal trip into Mr. Steering Column, to replace your switch! I do recommend, what I do in these type situations, especially if you do not trust your advisor. I'm not perfect, I'm not there to get the full atmosphere of your situation. Buy the new switch, unplug the old one, near the base of the column. Plug the new one in there, and test system, before tearing into the column to install it, verifying that being the solution to your problem. Get you a paper manual! Respond, your turn! I will shovel stuff, as long as you give me a place to throw it! Love, Turddog
https://images.2carpros.com/forum/automotive_pictures/411289_GOOD_OLE_WILLY_1.jpg
Apr 8, 2010 at 8:48 AM
