1988 Jeep Cherokee Hard Steering
TYLERFORREST84
Hi. I have recently acquired a 1988 Jeep cherokee, inline 6 I believe, 205,000 miles. When I bought the jeep, it had been abandoned on the highway, I checked it out and the steering stablizer was not bolted to the frame. It was attached by a bungee, I guess to keep from dragging the ground.
I got that all fixed and was hoping to hit the road; when I went to drive it, the steering still requires world's stongest man for operation. It does seem that when making a left turn it is easier, and the faster I'm moving as well. The power steering pump is operational as far as I know, but I don't really know.
Please if there are a couple of helpful tips you could provide, that would be great. I don't have any extra money or I wouldn't have bought a car from an auction to begin with. Any hints?
Feb 25, 2007 at 10:37 AM
CHEVY22
  • 1,375 POSTS
i wpold check the pump for pressure , pull the casp snd see if the fluid is moving around , you can also momentarily pich the high pressure line and see if you have fluid flying out of thepump if you do the pump works if not it may have broken the pump shaft internally and nwould not have any pressure
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 25, 2007 at 1:06 PM
Suggested Repair
Check power steering pump pressure and whether fluid is circulating in the reservoir. Momentarily pinch the high-pressure line; fluid forced from the pump indicates it is working, while no flow may mean the pump shaft is broken internally and the pump needs repair or replacement.
Conversation Summary
The owner of a 1988 Jeep Cherokee reports very heavy steering after reattaching a steering stabilizer that had been unbolted. Steering is somewhat easier when turning left and at higher speed. The expert advises checking pump pressure and fluid movement, and testing the high-pressure line to determine whether the pump is producing flow or has an internally broken shaft.
