1996 Jeep Cherokee Steering Line Blows
BRANDO34
Hey guys. Yesterday i changed the power steering pump on my 1996 jeep cherokee 2 door 4wd sport. It has around 190,000 miles. I got the pump on, filled the fluid, and started it up and when i turned the wheel i blew the return line off the pump. I then tightened that clamp down and thought i would be okay. Started it up and tried again and this time the return line blew off of the gearbox. It is a brand new pump and i have no idea what's going on. PLease help......The pump is definitely providing pressure to the gearbox because fluid went everywhere.
Oct 6, 2006 at 2:17 AM
DEMEARSJR
  • 110 POSTS
Did you have the cap off the resevoir when you turned the wheel?
Oct 6, 2006 at 3:08 PM
BRANDO34
no i didn't..i was going to bleed the system...i was told yesterday that my gearbox is probably bad. Found one for 50 dollars...hoping that is it
Oct 7, 2006 at 12:49 AM
DEMEARSJR
  • 110 POSTS
Try it one more time with the cap of the resevoir.
It will give the extra pressure somewhere to go.
Oct 8, 2006 at 1:05 AM
Suggested Repair
Retry with the power steering reservoir cap removed so excess pressure has somewhere to go. If the return line still blows off, inspect the gearbox, which may be restricted or failing.
Conversation Summary
After installing a new power steering pump on a 1996 Jeep Cherokee, the return line blew off at the pump and then at the gearbox when the wheel was turned. The owner planned to bleed the system and suspected a bad gearbox. The expert advised trying again with the reservoir cap off so extra pressure can escape.
