Power window
CURIOUS1
Can anyone help? I have a 2001 Jeep grand cherokee and something nasty happened when I was rolling up my power window :oops: and now it dosn't work. Need to take door cover off on the inside but can't see where to get started? Is everything just clipped in? There are only two screws that I can see.
Thanks for info, Curious1
Jun 10, 2007 at 2:57 PM
  • 75,988 POSTS
[quote:28e3df5212="Curious1"]Can anyone help? I have a 2001 Jeep grand cherokee and something nasty happened when I was rolling up my power window :oops: and now it dosn't work. Need to take door cover off on the inside but can't see where to get started? Is everything just clipped in? There are only two screws that I can see.
Thanks for info, Curious1[/quote:28e3df5212]
Check the fuse for it, if not you need to further check the master switch.
Jun 11, 2007 at 12:01 AM
CURIOUS1
Thanks for the reply, I should have mentioned that it is not a power issue as there is power but there is something broken inside the door panel and I need to take it off. I'm just not sure where it all clips in?
Thanks, Luis.
Jun 12, 2007 at 1:35 AM
SANCH78
I don't know much about cars but I know when the samething happened to my 99 jeep cherokee I was stumped! Being that both models are very similar maybe this can help. I unscrewed both of those screws that you are talking about and used a flat head to get underneathe the panel and pop it off. I started from the bottom incase I messed anything up. At the bottom they are these little plastic pop things soo after the first was off the rest were easy. Once I did that the panel felt really loose soo It was easy to take off then. BE CAREFULL IF YOU HAVE AUTOMATIC WINDOWS NOT TO MESS UP THE WIRING. I ALMOST DID. haha, Anyways, Once you fix what you have to fix get one of those plastic pop things and take it to the nearest auto store. I bought a pack for about 1.37 so it was easy putting the door panel back on. GOOD LUCK! Please read my post :( its under JEEP WITH SERIOUS PROBLEMS.
Jun 12, 2007 at 1:58 AM
