First the driver's side door wouldn't roll up, then the rear passenger's door wouldn't roll up. Is this something I can fix at home?
Mar 22, 2009 at 4:50 AM
JACCUERDON
MEMBER
1 POST
Open your driver door and look down betwen the door and the car. You will see a rubber housing that houses all the wiring for that equipment. It is a hassle, but peel or push that rubber back away from the door and inspect all the wires. I just had the problem, but a ground and a power wire were broken so none of the door's windows worked. I used a couple of but spices from home depot to fix it. good luck.
Mar 27, 2009 at 1:20 PM
KELLYS97JGC
MEMBER
I replaced the electric windows on the rear doors on an "01 grand cherokee. It cost over $250 per window and took a few hours. On the drivers door it may take longer due to power mirrors. Look at wjjeeps.com for door pannel removal etc.
