1994 Jeep Cherokee Pilot Bearing Stuck
BACAANDRES
i have a 94 cherokee, 4wd, 4 litre with about 160k miles. i am replacing the throw-out bearing and the clutch/pressure plate. i have discovered that the pilot bearing has completely disintegrated and the race is fused to the inside of the crank. i have tried dry ice to contract the race, but it will not budge. any suggestions?
Aug 13, 2007 at 5:20 AM
  • 75,988 POSTS
[quote:d34644552a="bacaandres"]i have a 94 cherokee, 4wd, 4 litre with about 160k miles. i am replacing the throw-out bearing and the clutch/pressure plate. i have discovered that the pilot bearing has completely disintegrated and the race is fused to the inside of the crank. i have tried dry ice to contract the race, but it will not budge. any suggestions?[/quote:d34644552a]
Pack it with grease and find the correct size pilot driver/rod and bang on it it'll come off. That's the old school
Aug 13, 2007 at 9:51 AM
Suggested Repair
Pack the crank bore with grease and use a correctly sized pilot driver or rod to drive the fused pilot bearing race out.
Conversation Summary
The owner of a 1994 Jeep Cherokee 4.0L 4WD is replacing the throw-out bearing, clutch, and pressure plate and found the pilot bearing destroyed with its race fused inside the crank. Dry ice did not free it. The expert recommended packing the bore with grease and driving the race out with a correctly sized pilot driver or rod.
