2002 Jeep Grand Cherokee Hot No-Start
ALEXDEAN
2002 Jeep Grand Cherokee Limited, 120,000 mi., 4.7 V8 engine, 4x4. Will start fine when cold or cool, but intermittently won't start when engine is hot. Has been a problem for the past 25,000 mi. Turn the key and it is dead--no starter noise or click or anything. Mechanic has replaced starter and battery with no results. Only way to get it started is to do the following things simultaneously, after turning off the a/c: jiggle shift lever and shift lever release button, press on brake pedal, turn key. Sometimes takes half a dozen attempts before it will finally start right up. Battery does not appear fatigued. Seems like an electrical connection somewhere. Any ideas? Thank you.
Jun 20, 2007 at 11:39 AM
2CARPRO JACK
  • 11,533 POSTS
There is a starter relay in the Power Dist Center. Have him test it for power in, and trigger when it wont crank.
Jun 21, 2007 at 1:07 AM
CRASH33
There is a Park position switch. If you are wiggling the shifter and it is having an effect, check this switch.
Aug 16, 2007 at 4:33 AM
GRICHARDS
  • 57 POSTS
glanced at post, first part made me think "heat related", second part about jiggling xmission shifter caught my attention. I'm initially thinking about your Neutral start switch - allows vehicle to start in Park and Neutral only. Will it start in neutral? Just looking for more symptom info... If it will start in neutral, you might have simply a dirty/lousy connection where
the connector plugs into the wiring harness, or dirty contact at the shifter itself. Don't know exactly where your NSS connector is for that model, don't know if you have a 3 or 4 speed auto trans...on side of xmission? Anyone else out there have this year model? Worst case, call the local auto parts stor and ask "em! Will check back to see if you find out any more info, Good luck!
Aug 16, 2007 at 2:04 PM
CHRISGSCOTT
I had this same *exact* problem last year. It's definitely the Neutral Start Switch. Wait long enough and all the jiggling in the world won't help it start, I'd get it checked out ASAP.
For curiosities' sake, do your reverse lights work right now? Mine wouldn't work while the NSS was bad. Random.
Hope this helps!
chris.
Aug 16, 2007 at 4:40 PM
Suggested Repair
Test the starter relay in the power distribution center for power and a trigger signal when it will not crank. Because shifting and jiggling the lever affects starting, inspect the park/neutral safety switch and its connector for a poor or dirty connection; also check whether it starts in Neutral and whether the reverse lights work.
Conversation Summary
A 2002 Jeep Grand Cherokee with a 4.7 V8 starts when cool but intermittently will not crank when hot, with no starter click. The starter and battery were already replaced. Starting sometimes requires turning off the A/C, jiggling the shifter and release button, pressing the brake, and turning the key. Advice was to test the starter relay and, given the shifter symptom, check the park/neutral safety switch and its connections. One owner reported the same issue was the neutral start switch and noted that reverse lights may also fail.
