1996 Jeep Grand Cherokee Stalling
Otherwise could be an idle air control valve, or just the injectors are a little clogged.
Suggested Repair
The ignition coil was already replaced with no change. Next, check the distributor cap and rotor, scan for codes, and inspect the idle air control valve. Also consider a professional fuel-injection service to address carbon buildup on the intake valves.
Conversation Summary
A 1996 Jeep Grand Cherokee with about 132,000 miles stalls, sometimes restarts immediately, and sometimes cranks but stalls or will not start. Fuel pressure tested fine, and the crankshaft pickup, ignition sensors, exhaust manifold, fuel filter, spark plugs, filters, and ignition coil were replaced without resolving it. Experts suggested checking the distributor cap and rotor, scanning for codes, inspecting the idle air control valve or injectors, and performing a professional fuel-injection cleaning for carboned intake valves common on 4.0 engines.
