2003 Jeep Grand Cherokee Fan Won't Stop
KATCH614
The engine fan on my 2003 Jeep Grand Cherokee Laredo (27,000 or so miles on it) is still running even after I shut off the engine. No indicators lights have come on suggesting any trouble. If I have to take it in to the dealer for servicing, will it drain my battery until I can get there?
Mar 16, 2006 at 3:08 AM
VANDRAGON
  • 298 POSTS
if it doesn't ever go off, it sounds like a bad temp sencer or relay. if it's a 2003 with only 27,000 miles and was sold or built sometime after this month, it should still be under warrenty. check between where the drivers door closes for a sticker that has final assembly date. i hope this helped!
Mar 18, 2006 at 3:02 AM
Suggested Repair
If the cooling fan never shuts off, have the temperature sensor and fan relay checked. Also check the final assembly date sticker where the driver's door closes; with about 27,000 miles the vehicle may still be under warranty.
Conversation Summary
The owner of a 2003 Jeep Grand Cherokee Laredo says the engine fan keeps running after the engine is turned off, with no warning lights, and asks whether it will drain the battery before a dealer visit. The expert says a fan that never turns off is likely a bad temperature sensor or relay, and recommends checking the driver's door-jamb final assembly date because the low mileage may still be covered by warranty.
