1990 Jeep Cherokee Fuse Blows After Hatch Work
Good luck, BYM
Looking back through some recalls, I wonder if that wire caused a problem before and the recall fix was to disconnect it. For your reference, it is a very small male to female connection wire harness with two blue wires on one end and a black on the other located right next to the left rear speaker.
Thanks for your help.
thanks.
Suggested Repair
If fuse 7 blows immediately after hatch or dome-light work, disconnect the small two-wire harness beside the left rear speaker (two blue wires to one black) if it was reconnected. Also inspect the dome-light wiring for pinched wires before chasing the rest of the circuit.
Conversation Summary
A 1990 Jeep Cherokee owner replaced the rear dome light and rear wiper motor, then fuse 7 began blowing immediately and the rear running lights, instrument panel, and radio stopped working. An expert suggested checking whether the dome light shared that fuse and whether wires were pinched. The owner later found that reconnecting a small harness next to the left rear speaker caused the short; unplugging it restored the running lights. Other Cherokee owners reported similar fuse-blowing issues after reconnecting hatch wiring.
