1996 Jeep Cherokee Differential Leak
MHOCKERT
I have a 1996 Jeep Cherokee Country w/ almost 141,000 miles on her. She's been good so far and I have been replacing so much lately. I put on new tires which are 1" taller and wider then the standard tires. And it started vibrating, did the checking of new tires, it had new u joints and bearings, rotors, pads, drums and rear u-joints, leaf springs.... even checked the alignment. Started leaking gear fluid at one point and had almost none left, I won't even touch the fact of how many times the dang thing was on lift and no one noticed the fluid all underneath my truck. And she doesn't always show when she injured so no noises to make me question. Can I fix this? How do I fix this without financially putting myself in a hole? Do I rebuild or buy salvage? A new one would make me cry, I know that. My mechanics are great but I need another perspective. Thanks..... Megan
May 12, 2007 at 10:32 AM
SERVICE WRITER
  • 9,123 POSTS
Larger tires can cause problems I wouldn't suggest it, although haven't looked into it. Your "great mechanics" should have seen the leakage and at the very least should have checked the level. I wouldn't be happy about that. Used would probably be the cheapest, but comes with a question of quality. IF you know of a quality rebuilder that offers a good warranty, that may be the best option.
May 12, 2007 at 11:45 AM
Suggested Repair
Avoid relying on larger tires, which can cause driveline problems. A quality rebuilt differential with a good warranty is likely a better option than a cheap used unit of unknown condition; have the leak and fluid level corrected.
Conversation Summary
The owner of a 1996 Jeep Cherokee with about 141,000 miles reports vibration after installing taller, wider tires and a gear-oil leak that left the differential nearly empty. They ask whether to rebuild the differential or buy a salvage unit. The expert advises against larger tires, notes the leak should have been noticed, and says a quality rebuilder offering a warranty may be better than a used unit of uncertain quality.
