92 Cherokee stranded at mechanic
COREYBAUER
  • 1992 JEEP CHEROKEE
Please help me if you can.
I have 92' Jeep cherokee and it recently has hit the wall. I took her in because I had to bet a new crankshaft/bearings that caused a my rear engine seal to leak oil. After spending a a lot of money on that. The cars seems fine. Until
4 days later. Take car to supermarket, come out and its dead. And I mean dead, no lights (inside or out), no automatic doors. Everything is dead. Seemingly, the car did not start.
So I'm thinking the battery is dead. Maybe I left my lights on or something. I come back in a couple hours with jumper cables. Before we hook everything up, I open my doors to see the lights are working again inside (but not in ful).? I hook up the jumper cables and power is restored throughout the car. Wait a few minutes and then try to jump her. Then nothing happens (well I shouldn't say nothing. The battery started sparking a little bit. All the lights go dead agian). But never ever did it start or get near starting
So I take it in. The mechanic says my battery is fully charged. And cannot what is wrong? He mentioned some kinda security system. That could be telling "the internal computer" to not start the car. But I have dealt with this security system before. Usually the lights and everything will work but the car won't turn over. But this is different. As my car simply will do nothing.
Anyone have any ideas? I got my car sitting at the mechanics shop that says he cannot do anything.
All the help is greatly appreciated. Cus im lost .
thanks
Friday, October 19th, 2007 AT 9:59 AM
BLACKOP555
  • 10,371 POSTS
To turn off the system remove power from battery for a minute or two then reapply. Does it do the same thing? It could be a bad ignition switch or relay. Have him test the ignition system.
Friday, October 19th, 2007 AT 10:08 AM
COREYBAUER
Thanks for the reply. Anything helps. Although I know some stuff. All this is outside my expetise. So I wanna say thanks
but also.
You say remove power from battery. Does this mean to take off battery cables?
Otherwise. I agree must be a relay. From battery to alternator or something?
Thanks again
Friday, October 19th, 2007 AT 1:00 PM
BLACKOP555
  • 10,371 POSTS
Yes remove the negative battery cable then reatatch it. When you jumped the car you could have hooked up the cables wrong causing the sparks from the battery and the lights going dead. Have him test the ignition relay.
Friday, October 19th, 2007 AT 2:38 PM
COREYBAUER
That is what I thought too. But double checked when they were on there. I will do this tonight and get back at you.
Thanks.
Friday, October 19th, 2007 AT 5:30 PM
