HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Engine
Symptoms
Idle High
SPONSORED LINKS
91 Jeep Cherokee 4.0L AT 200,000 miles
RELLIKNIKCUF
MEMBER
1991 JEEP CHEROKEE
What sensor, if bad, will cause an erratic and high idle cold and hot and a major shift in the transmission shift points?
It might be a bad ground on the sensor in question, but I need to know which sensor it is.
Thanks to anyone brave enough to provide an answer.
SPONSORED LINKS
Wednesday, April 18th, 2007 AT 4:42 PM
MERLIN2021
MECHANIC
Not that easy. Is it fuel injected or carb?
Thursday, April 19th, 2007 AT 5:14 PM
RELLIKNIKCUF
MEMBER
It is multi port fuel injected. It has a distributor. Timing is electronically controlled.
The problem is intermittent, I'm just trying to target the problem without attaking the entire electrical system with a multimeter.
Thanks for the response.
SPONSORED LINKS
Friday, April 20th, 2007 AT 10:26 AM
RELLIKNIKCUF
MEMBER
Turned out to be the TPS.
Sunday, July 1st, 2007 AT 7:32 PM
Please
login
or
register
to post a reply.
Related Engine Idle High Content
1991 Jeep Cherokee Engine Idles High, Stalls &...
Hi, I Have An Intrmitent Problem Which Seems To Be Getting Worse. Sometimes It Runs Fine, Other Times The Idle Will Go To 1000 Rpm And Not...
Asked by
WAPITIMN
1 ANSWER
1991
JEEP CHEROKEE
1991 Jeep Cherokee High Idle
Wony Idle Down Most Of The Time Sometimes When U Start Its Fine The Warmer The Engine The Higher The Idle Use To Restart To Fix Doesnt Help...
Asked by
jake29
1 ANSWER
1991
JEEP CHEROKEE
1988 Jeep Cherokee Curbside Idle Very High
I Just Installed A New Exhaust Manifold And A New O2 Sensor. When I Started It The Idle Speed Was Very High (perhaps 2000 Or More Rpm). I...
Asked by
Jayanne
1988
JEEP CHEROKEE
1988 Jeep Cherokee Clarification On High Idle Problem...
In Warmer Weather My Jeep Periodically "sticks" At Max Rpms Upon Starting. Can Be Corrected By Disconnecting/re-connectiing The Wire Harness...
Asked by
gthopkinson
1988
JEEP CHEROKEE
High Idle
I Have A 88 Jeep Cherokee W/4.0l I6 When I Start It, It Will Sometimes Idle Really High Then If I Give It A Second Will Idle Back Down To...
Asked by
cainmos
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Online car repair manuals
