2006 Jeep Grand Cherokee - Vibration at Stops
2006 JEEP CHEROKEE
TIMO
I have a new 2006 Grand Cherokee Laredo, V6, 4WD with only 1500 miles. After the first long drive (i.e., opportunity for transmission and engine to warm up), have noticed a significant vibration when coming to a stop (stop sign, traffice light) while the engine is at idle and foot on brakes. The vibration is severe enough to feel in steering wheel and create a sound (sounds like a diesel truck). Although most obvious at a full stop, vibration also occurs at very low speed (i.e., just after removing foot from brake when going forward or in reverse before applying foot to accelerator). The dealer's repair shop indicated that they couldn't recreate and solve the problem (the problem often isn't apparent until engine/transmission warms). I've seen postings on the web of similar problems with other vehicle types...often blamed on either motor mount problem, exhaust problem, or other. But I've not heard of this problem in the Jeep. Any suggestions as to what this may be....and how to get the dealer to acknowledge the problem and fix?
Jul 23, 2006 at 7:32 AM
DEMEARSJR
  • 110 POSTS
Rotors could be warped if it takes a while before it happens. You didn't mention if there was any noise associated with the shimmy.
Jul 23, 2006 at 2:47 PM
TIMO
No. It is not the brake rotors. The vibration occurs once the vehicle is at a complete stop....not while stopping. (I would recognize rotor vibration...since I've been driving other Jeeps for 10 - 15 years.)
Tim
Jul 23, 2006 at 3:38 PM
DEMEARSJR
  • 110 POSTS
When it's in drive but at a complete stop. Could be either motor or tranny mount.
Jul 23, 2006 at 3:43 PM
