2004 Jeep Cherokee Driver side controls located on door do
63,000 MILES • V8 • AWD • AUTOMATIC
JEEPINJAN
driver 1 and 2 button selections do not work. Mirror control does not work. Power door lock button does not work. Courtesy lights when door is opened does not work. (It does come on when passenger door is opened). Passenger side power door lock does work. I hear clicking somewhere in center console that don't think I've heard before. Windows do not open on any control on any of the doors. (I did check window lock and it is disengaged)
Oct 9, 2009 at 11:31 AM
JDL
  • 16,098 POSTS
Welcome, when there is more than one problem, I pick one and start there. Power windows, fuse 12--50a in power distribution center under the hood, use teslite check fuse circuit for voltage, hot all the time, also check that the fuse isn't blown. Next, check the circuits at master switch in driver door. Orange wire with white tracer is voltage to the switch, black wire is ground.
Oct 10, 2009 at 3:25 AM
