1996 Jeep Cherokee driver's door
JEWLS12
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • MANUAL
  • 149,000 MILES
I have the inside panel off of my jeep driver's door removed, and it still will not open, what might be the problem? Seems like it might be the lock. How can I remove the door?
Monday, August 24th, 2009 AT 6:31 PM
  • 109,874 POSTS
Has the linkage come apart?
Monday, August 24th, 2009 AT 8:56 PM
JEWLS12
The linkage seems to be connected- the guts connect when the handle is pulled. If the lock were broken, would it prevent the door from opening?
Monday, August 24th, 2009 AT 9:01 PM
  • 109,874 POSTS
I would think the lock could do it. Do you have any way to access the actuall latch?
Monday, August 24th, 2009 AT 11:18 PM
JEWLS12
I can manually pull the latch- it still won't open the door. I can hear the connection catching, though.
Tuesday, August 25th, 2009 AT 12:54 AM
