1988 Jeep Cherokee drivers door
CWEYLAND75
  • 1988 JEEP CHEROKEE
  • 4 CYL
  • 4WD
  • 160,000 MILES
How do I get the door open if unlocked wont open from inside or out have managed to get panel off pushed pulled on lock
Friday, October 23rd, 2009 AT 6:44 PM
  • 31,937 POSTS
Him there,
As you have the trim off, locate the rod that activates the lock mechanism from the external handle, pull this up or down depending on which way it operates, also check that the pin lock button is up, you should be able to trigger the lock with a screw driver, you may need to remove the other door trim to see how it all works as I cant find a decent pic to post, will do so if I come across one.
Mark (mhpautos)
Friday, October 23rd, 2009 AT 9:10 PM
