2002 Jeep Cherokee not heating right
35,000 MILES • V8 • 4WD • AUTOMATIC
GABRIEL_01
  • 6 POSTS
I have a 02' jeep grand Cherokee 4.7 Lt.
My passenger side actuator went out on me so i had to change it first time doing a job this big I replace the actuator got everything back in but now my cheep is not heating correctly it does not blow enough hot air
I'm not sure if i put the heater core hose's on correctly from the firewall the top line to the bottom of the water pump and the bottom of the fire wall to the top of the water pump
the temp. Gage is normal its not overheating
my top radiator hose is hot but the bottom one were the thermostat goes is cool ?
does my jeep have a heater control valve if so were is it could that be it ?
Dec 17, 2007 at 5:50 PM
  • 75,988 POSTS
Try removing the thermostat and see what happens
Dec 17, 2007 at 7:20 PM
GABRIEL_01
  • 6 POSTS
[quote:ef91eb702c="rasmataz"]Try removing the thermostat and see what happens[/quote:ef91eb702c]
thank you for your help i removed the thermostat to be safe I flush the system with a water hose put the same thermostat and its working fine.
P.S If the system had air will that cause poor heat
Dec 18, 2007 at 1:55 PM
  • 75,988 POSTS
Yup the air lock will choke it
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks
Dec 18, 2007 at 3:52 PM
