2001 Jeep Grand Cherokee No Heat
U4EA
I own a 2001 4.7 g/c and the interior heater does not work, i can feel heat at the control panel but no hot air in coming out of the vents. Spoke to a person at my local dealer and was told " oh yes there is a modification to be done" so i would like to know what is the problem with this i am not interested in having the dealer work on my car and would like to fix it myself.
thank you
Jacques
South-Africa
Sep 20, 2006 at 10:29 PM
DEMEARSJR
  • 110 POSTS
The issue you're experiencing with your 2001 Jeep Grand Cherokee, where the interior heater does not work despite feeling heat at the control panel, could be caused by a few different factors. One common problem in this model year is related to the blend door and the blend door actuator. The blend door is responsible for directing the flow of air from the heater core to the vents to control the temperature inside the vehicle. If the blend door is stuck or the blend door actuator is malfunctioning, it can result in a lack of hot air coming out of the vents.
Here are some steps you can take to diagnose and potentially fix the issue:
Check the Blend Door Actuator: The blend door actuator is an electric motor that controls the movement of the blend door. Listen for any clicking or grinding noises coming from the dash when you adjust the temperature settings on the control panel. If you hear unusual noises, it may indicate a faulty blend door actuator.
Inspect the Blend Door: If the blend door actuator is working correctly, check the blend door itself to ensure it moves freely and is not obstructed or broken. Sometimes, the blend door can get stuck due to debris or other issues.
Perform a Heater Core Flush: A clogged or restricted heater core can also result in poor heating performance. Consider performing a heater core flush to remove any debris or sediment that might be blocking the flow of hot coolant.
Check the Heater Control Valve: The heater control valve is responsible for regulating the flow of hot coolant to the heater core. Ensure it opens and closes correctly when you adjust the temperature settings on the control panel.
Inspect the Vacuum Lines: Some HVAC systems use vacuum-operated components to control the blend door and other functions. Check for any disconnected or damaged vacuum lines that may be affecting the heating system.
Scan for Diagnostic Trouble Codes (DTCs): Use an OBD-II scanner to check for any stored diagnostic trouble codes related to the HVAC system. DTCs can provide valuable information about the specific issue.
Refer to Service Bulletins or Technical Service Manuals: As the dealer mentioned a "modification," there might be relevant service bulletins or technical service manuals that address this issue for your specific model year. You can search for these resources online or at automotive repair information websites.
Sep 24, 2006 at 3:46 PM
U4EA
I dont know if it could be the heater motor , it blows air out of all the vents at all speeds but not hot air even if you select the the hottest setting the air is still cold but you can feel heat at the controle panel ?
I am thinking it could be a valve of some sort thats either sticking or not working any ideas ???
What do you mean by "flushing" the system ?
thanks
Sep 24, 2006 at 8:50 PM
DEMEARSJR
  • 110 POSTS
Flushing is when they force water through the system to remove any sludge or blockage in the system.
Does the engine heat up normally?
Sep 25, 2006 at 2:37 PM
U4EA
Hi
Yes the engine heats up normaly no problems there, its just that no hot air is coming out of any vents cool air and a/c works fine and as i said if you put your hand on the panel where you select the temp of the air you can feel that that gets warm from the air but only cold air comes out of the vents, i am stumped !
Sep 25, 2006 at 10:24 PM
DEMEARSJR
  • 110 POSTS
Could be the heater bypass valve is stuck or the heater core is blocked.
I'd check the heater core first.
Sep 27, 2006 at 12:00 PM
Suggested Repair
Check the heater core first for a blockage, then inspect the heater bypass valve for sticking. Also consider the blend door and actuator, a heater-core flush, vacuum lines, and any related HVAC codes or service bulletins.
Conversation Summary
The owner of a 2001 Jeep Grand Cherokee reports that the blower and A/C work and the engine reaches normal temperature, but only cold air comes from the vents even on the hottest setting, while the temperature control panel feels warm. The expert says flushing means forcing water through the system to clear sludge or blockage, and recommends checking the heater core first because it or the heater bypass valve may be blocked or stuck. Blend-door and actuator problems were also suggested earlier.
