2001 Jeep Cherokee power window problems
2001 JEEP CHEROKEE
192,300 MILES • 6 CYL • 4WD • AUTOMATIC
FUNWMYJEEP
I have an 01 Jeep Cherokee and none of the power windows work. I have replaced the fuse and the window lock is off. I'm not hearing the window's motor run. Is it a bad switch or a problem at the fuse box. The power door locks work and the mirror switch works. Any ideas?
Thanks,
Dan
Jun 23, 2009 at 4:19 AM
GIANTSCALERCGUY
  • 5 POSTS
Take off the driver's side door panel and make sur the plug that goes to the wundow lock is plugged in and secure. If it is, unplug it, and try to operate windows. Still no action, check lock switch with a meter to assure it is operating properly. If so, check power to switch plug.
Good luck
Jun 29, 2009 at 4:10 AM
