2001 Jeep Cherokee cooling fan
FGASTON
Engine Cooling problem
2001 Jeep Cherokee All Wheel Drive Automatic 95000 miles
my engine is heating up. i changed the thermostat--no difference. i tested the fan and it will run by direct current. i changed the temperature switch and stiil i heats up. is there a relay somewhere that i missed and if so where is it located?
Sep 1, 2009 at 3:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check relay, it is located under the passenger side head lamp mounting panel. you can remove both head lamps and hood latch to access it OR cut a small 2" x 2" hole to gain access to it.
Sep 1, 2009 at 8:43 AM
