2001 Jeep Cherokee car wont start
B2G2001
  • 2001 JEEP CHEROKEE
  • V8
  • 4WD
  • 90,000 MILES
I parked my jeep in the garage the other day and then tried to start it the next day it would almost turn over but would never fire up. If you have any ideas that would be great
Monday, August 10th, 2009 AT 11:39 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard
Tuesday, August 11th, 2009 AT 12:01 AM
