2001 Jeep Cherokee Brand new battery corrosion
2001 JEEP CHEROKEE
65,000 MILES • V8 • 4WD • AUTOMATIC
BRETT1818
  • 10 POSTS
2 years ago the Jeep dealership replaced my battery in my '01 Jeep Grand Cherokee. The uncovered terminal on the old battery had a LOT of corrosion on it and was causing electrical issues. The dealership said I also needed a new battery when I took it in, so I went ahead and replaced it.
NOW the new battery terminal is doing the same thing. When I pull into my garage I notice a very slight burning smell, and there is a good amount of corrosion on the uncovered battery terminal. Is there anything I can do to keep the corrosion off the battery?
Dec 31, 2007 at 4:14 AM
FAIRRACING31
  • 150 POSTS
Your battery will always have corrosion. I clean my vehicle's battery terminal sometimes up to four times a year. I use water and bakingsoda to wash the terminals, cables, and battery several times a year to help prevent corrosion. Also use a battery post cleaner
https://images.2carpros.com/forum/automotive_pictures/103836_Battery_1.jpg
You can also use felt washers that go between the battery terminal and battery
https://images.2carpros.com/forum/automotive_pictures/103836_Felt_1.jpg
Also, you may use connector grease to put over your terminals. All of this helps prevent corrosion, but it wont stop it.
https://images.2carpros.com/forum/automotive_pictures/103836_agsbt1sp003_1.jpg
Happy New Year :)
Dec 31, 2007 at 10:23 AM
