2000 Jeep Cherokee Engine Noise
2000 JEEP CHEROKEE
15,000 MILES • 6 CYL • 4WD • AUTOMATIC
RSTEWART
This is a very clean and well maintained Grand Cherokee Limited. Was driving with the radio on. After turning the radio down a noise can be heard coming from the engine. It sounds as if it is possibly a wrist pin. It does not sound low in the engine. I removed the valve cover and do not see anything out of the ordinary. Is there a common piston or wrist pin problem in these vehicles? This is a 4wd Jeep but can the oil pan still be removed without pulling the engine? Thanks for the help.
Dec 7, 2009 at 10:37 AM
CHULEGAARD
  • 35 POSTS
Is it like a tick? These are not known to be quiet motors. Remember these are a truck not a car. What do older trucks do??? Yep exactly they make noise.
Dec 9, 2009 at 8:51 AM
RSTEWART
After dropping the oil pan, I found the broken pieces of a piston skirt in it. It appears only one piston broke. I was expecting cylinder damage, however the cylinder is smooth with no marks at all. Hopefully I will be able to replace this piston and all bearings and be back on the road.
Dec 13, 2009 at 9:42 PM
