Also, the starter sounds like it is dragging when I crank it, and the belt has been squealing for a while now, but it has gotten worse recently. Also, when I cranked it to see if the thermostat did the trick, it was hard to keep it idling, and it cut out a lot. I didn't allow it to run while it was hot.
My question is, could all this be because the serpentine belt needs to be replaced, or should I begin changing other parts to stop the over-heating. Water pump, fan motor etc?
Thanks in advance for any input!
SPONSORED LINKS
Monday, October 25th, 2010 AT 4:36 PM
