2000 Jeep Cherokee overheating
110,500 MILES • 6 CYL • 4WD • AUTOMATIC
CINDYK99
help!!!! I have changed the water pump, hoses, thermostat, had the radiator flushed and had the head gasket replaced, engine is still overheating. I have been dealing with this issue since last April. I have used over 5 gallons of antifreeze since January, no external leaks...I don't know what to do next...please help
Mar 8, 2009 at 6:07 AM
HELPING YOU
  • 100 POSTS
What are pressure test results? Have you tested the cap? Combustion gas detected? I'd like to poke around with an infrared temp. gun if these tests all pass.
Mar 8, 2009 at 6:30 AM
CINDYK99
All passed, I have also replaced the radiator cap twice
Mar 8, 2009 at 6:37 AM
HELPING YOU
  • 100 POSTS
With a temp gun you can get an idea what's going on - if stat's working, radiator flow, etc...
I've heard of an impeller falling off the water pump but never seen one...
Mar 8, 2009 at 7:53 AM
